Good evening, my knowledge with heating isn't great, so thought ide seek some advice.
At current there is a heating system (Gas boiler) which is serving heating (rads) / hot water. The plumber has said he's slightly puzzled from the system to weather its a Y or an S plan.
They've had an extension built which has 2 zones of underfloor heating using the UFH3 wiring plan and the heatmiser wiring base I've wired up as diagram and with the SL to boiler.
The client wanted it so if they want Heat on in the extension it wouldn't heat up the rads in the rest of the house at the same time. I presumed that just wiring the SL from UFH into the boiler same terminal as the SL from original system that would be sufficient. Meaning that if the room stat from the rad system was satisfied it wouldn't heat that system anyway.
Had a phone call today with the client saying when they've got the rad system turned off and stat fully up the rads are still getting hot?????
Think i may have made a silly mistake and wondering if a contact or something should be fitted?
Would like it if someone could help thanks.
Liam
Liam
