O
Oyarsa
I had an Intermatic timer light switch that seemed to stop turning on and off automatically. I bought a Defiant replacement.
The old switch had wires coming from it which were attached to the corresponding wires from the wall. The new switch did not come with any wires aside from two jumper wires. I connected all the appropriate wires from the wall to the switch easily, but the ground wire from the wall terminated in a screw cap with several other ground wires, and so I didn't have a wire to connect from the ground on the switch to the other ground wires.
Being white, I used one of the jumper wires to connect from the light switch to the screw cap the old ground wire was connected to. Everything works fine, but in hindsight, I'm not sure if this is appropriate. Should I go buy some more appropriate wire?
TL;DR
Used a jumper wire to connect ground from light switch to other ground wires. Is this ok?
I can possibly tonight.
Thanks.
Sorry to take so long to post the pictures. I'm glad you asked, because I misspoke. It wasn't the ground wire that I used the jumper for. It was the neutral wire. So now the question is whether the jumper wire can be used as a neutral wire.
Hopefully these pictures aren't too large to post.
That looks a little "busy" in that box for a 2G switch!
Isn't there any issue with that bare ground wire folding against things it shouldn't when it's all pushed back into the box?
I'm curious now, too. I certainly wasn't cautious when I pushed things back in. What should I be worried about it folding up against?
This is normal US practice. I don't get it either, what with the exposed binding screws on the side, but they're not into sleeving.
Yes you are fine if you used white and it should be mark with green tape and if it’s terminated in the wire nut with the other grounds
