Discuss Using rebar as earthing. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The reg. doesn't say 'should' - that was me, sorry.
542.2.3 Suitable earth electrodes shall be used...
(v) Welded metal reinforcement of concrete (except pre-stressed concrete) embedded in the ground.
Usually tied together with stainless steel wire.
As for connecting to it: drill into the top of a piece purposely left sticking out, tap a thread then connect with a ring crimp and a bolt, cover with grease to stop rusting. Is how I'd do it.
Not what you would term "light" reading!
It explains some of the things I've been doing since starting in the industry.
Also an appology to Herb Ufer for keeping on spelling his name wrong.
Reply to Using rebar as earthing. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
