Discuss Voltage still detected after rcd had tripped? why could this be... in the UK Electrical Forum area at ElectriciansForums.net
Use a multimeter/ MFT rather than a voltstick to confirm what voltage is where. Voltsticks are useful but only give an indication and can be easily confused by capacitive coupling / induced voltages.
E: and again we have proof that great minds think alike, although Tel types faster
i like to think they show potential, potential to injure yourself or generally make yourself look like a --- waving a stick with a flashing red beacon like some crazed harry potter fan
All,
I have to say, (with a few exceptions) you come across as a **** taking bunch of smart arses. You all use volt sticks, you are telling lies if you say you don't. I never said that I rely on this method to confirm voltage. It was an observation and wanted to ask other people.
With-in a few replys this forum has 'Assumed' I don't know what im doing.
I future I will think twice before I post. Ouch!
PS: Many thanks to those who offered sensible responses.
All,
In which case you should use the "thanks" button so we can see which ones you appreciate!
All,
I'm not lying, I definitely don't use them. I have used voltsticks in the past, but in my experience they give false readings either live when dead or vice versa.
If I had used one and got a spurious reading however, my first thought would be to prove with my AVI what was going on, not ask an internet forum. That would give the impression I don't know what I'm doing or have the right tools for the job. I think that is what you have got stick for.
Quick few games to show voltsticks pick up stray and non dangerous currents.... place voltstick near tv screen... rub voltsick on your jumper, all will lite the voltstick, but non are dangerous.
Yes, I agree that voltstick is not a 100% guarantee, I will test what voltage is present when I go back to finish the job, just had never noticed this before.
Cable bunching can confuse a voltstick,
however, the RCD (to my understanding) should break the power on both live and neutral. So there should be no current available to detect on the load side of the spur and bathroom circuits.
This can be overcome by using your finger on the end of the voltstick and slightly separating the cables as you scan.
I use a voltstick on a regular basis and it has served me well over the years in fact I would go as far as saying that it's potentially saved my life on at least a couple of occasions when I unwittingly came across a 'borrowed' neutral, that's after safe isolation was carried out, all appeared okay until I split the neutrals and one magically became live! They're also great for detecting broken neutrals in extensions.
Reply to Voltage still detected after rcd had tripped? why could this be... in the UK Electrical Forum area at ElectriciansForums.net
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hi I am asking for help as a novice and 1st time user of this forum. Recently started to experience tripping of MCB & sometimes with the RCD at...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
