Discuss Wago's , junction boxes and choc blocks whats best with downlighters in the Electrical Tools and Products area at ElectriciansForums.net
I do the same as mal, Ashley 501 on each down light and a bit of heat proof coming off to feed the light, if a 12v tranny straight out of the Ashley. Personal opinion I don't like seeing all the down lights wired back to one JB it looks a bit Heath Robinson though there is nothing wrong with it.
I have to admit though there is nothing wrong with having the 5 lights on the one JB, it's going to be a nice tight fit in that single JB, at a minimum 6 cables, and if you a fault on a fitting, and need to remove it to say buy a replacement your going to either have the other 4 lights off, or make that on leg safe, whereas a JB for each light is a lot easier.
Having just completed the job I have to agree with you ... it would have been better to go with one Ashley per downlighter!
The Ashleys are nicer to use than the old round junction boxes and have the cable clamps ... but 6 cables into one of them and it sure gets crowded in there ... had to connect the earths into a separate single junction (taped up and enclosed inside the Ashley) as there was just not enough room to work.
well i used them click flows this week and i swear i hate it.... keep on about these wagos, but nobody round here stocks them... hate downlights with junction boxes , worst job in installation
You can order wagos and all the bits to go with them from wagobox.com postage is reasonable too, I just got a box of them wago lighting boxes to try out for downlights.
New posts
Reply to Wago's , junction boxes and choc blocks whats best with downlighters in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, I am about to fit a light fitting and wanted some advice whether I should just connect the light cables into the correct terminal blocks...
I collect old Electrical Fittings and I recently acquired this vintage Junction Box (photos attached). I've been trying to figure out how it would...
Hi, Hopefully I haven't made an error but I was speaking with another electrician and he said standard junction boxes with screw terminals can no...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
