No im not, landlord.Are you a tenant?
Im working away so its on rent to cover mortgage as im renting elsewhere. All these regs make it unaffordable for me.
I know! Bloody safety!No im not, landlord.
I think other things you mentioned will bring a C2...
You are in the same boat as every other landlord in the country.... regarding regulations.
I thought at the time of installation if it was upto regs it would be fine. It is a wylex mcd board with RCD.I know! Bloody safety!
I got this from a websiteI think other things you mentioned will bring a C2...
I think you misunderstood, i jave mcb for shower, 2 socket mcb's and one for lights. The rcd is in the place of isolator it wasnt changed by me, its the old ac type, its an old council house and they wouldnt have replaced isolator with rcd if it wasnt upto regs. These are the old wylex fusebox, max 5 mcbs could be added.Its hard to say.
Its up to the engineer at the time to decide what is a C1, C2 or C3....if the . and some will err on the side of caution. However, there is also the argument that they code things harshly to generate more work for themselves. (you don't need to use the same company for remedials) Possibly a letting agent or licensing would also require you to have a minimum standard concerning safety.
confusingly, you say the board isolator was changed to an RCD at some point, probably to cover circuits that should be RCD protected... but then you say only the sockets and shower have an RCD?
I dont have pic but it small version of this one but can only hold on 5 mcbs. Instead of isolator it has rcb.Can we see pics of the consumer unit?
Instead of penny-pinching just upgrade the consumer unit to a spd + rcbo one.I dont have pic but it small version of this one but can only hold on 5 mcbs. Instead of isolator it has rcb.
Electrician Musk Community | Does anyone know if the Wylex mini rcbos fit in the older style fuse boards | Facebook
Does anyone know if the Wylex mini rcbos fit in the older style fuse boardswww.facebook.com
