Discuss What class test for 110v extension leads (Not on reels) in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
its a Class 1 test, if you dont have a fancy set of test adapters for this you can get a 6 inch nail,connect the Crocodile clip probe and put the nail in the clip, then zero it on the PAT tester machine, after that you can stick it in the Earth slots in the spider sockets and the commando sockets on the end of the leads to do an Earth bond test (the 25A one)
Reply to What class test for 110v extension leads (Not on reels) in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi All, My colleague and I are currently doing PAT/ISITEE Testing, and we've hit a snag with a bit of equipment - we've got 19" Racks for our...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Hi guys and gals, I have a question about the leads to computers (commonly known as kettle leads). I am new to PAT testing so please bear with...
Hi guys, We’ve had a new CNC Machine from China arrive this week. It came with a monitor and a tower to run the software. The monitor and tower...
I am using a 160watt-200watt multi uv tube stand alone sunbed,When the 2 power leads (plugs protected by 2x13amp fuses) plugged into a double wall...
