Discuss What CSA is the Neutral conductor in this split load 17th CU unit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
F
freedomrun
Had a look at a split load 17th edition RCD CU, quite new - one of the sides has a solid copper neutral that runs off to the Neutral bar on the DP isolator of the CU. Basically, due to a loose connection, a bit of Arking has gone on and made a mess. I want to put a new Neutral in to replace the damaged one - what is the CSA of the conductor used in these CU's (it's just a solid copper bar that has blue insulation and bends around the back of the MCB's) I want to replace it with some new cable, the DP switch is rated at 100A on the CU. I'm thinking it may be 16mm, just want some advice please. Also - would this just be a maintenance issue or should i issue a MW also?
I've plenty of 16mm CPC, seems silly going to buy more copper when only the insulation colour is different, I have 25mm tails, no 16mm in blue at the mo.
Reply to What CSA is the Neutral conductor in this split load 17th CU unit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello. New member here. Electrical enthusiast. I am at a friend's house in the Bahamas and decided to look at the load center in the house, which...
Hi all, My question relates to the omission of overcurrent protection (specifically overload and fault protection) at the origin of an...
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
