Search the forum,
Discuss what do you call this fuse? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Sounds very similar to a C/U swap we did the other week, main fuse cover had no seal and loose - so was partly open to show a fused neutral - and a strap around the sheath which ended up testing to show no connection to any supplied earth.... Needless to say that the C/U was a complete mess in the same cupboard too small for Frodo!
I also got everything upgraded on my house a couple of months ago before I rewired, and just told them it's could possibly be a fused neutral, the guy came out and changed it no quibble for me.
Reply to what do you call this fuse? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
About 15 years ago, after having had a modern consumer unit fitted, and prompted by our electrician, I asked my then energy supplier (Tonik) if...
5K
I might be overlooking something that's right under my nose but opinions would be much appreciated. I visited a customer today with a detached...
Folks, Called out to a semi-detatched rental property today...TT, semi-enclosed wired fuse board, 4-way with a 500mA Earth Leakage Voltage main...
My customer needs bigger than 60A supply. Currently BS1361 60A. 4 bedroom house, 4 kids, new circuits.. Before I started in the place it came up...
6K
Knobhead
K
E
I think I've Posted this before, but I've just updated it. Some of the sparks where I work still get a little confused of what the different areas...
78K
