Discuss What is this part (that binds multiple wires) called and how do I remove it? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
looks like lead, so can easily be cut off . either that or cut the conductors.
Make sure the power is isolated if that's a mains voltage connection.
It's some type of crimped ferrule that makes a permanent connection.
As above make sure it's not live and cut it off. If you need to make a connection again use a Wago connector or an equivalent.
Reply to What is this part (that binds multiple wires) called and how do I remove it? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Our Northern California home built on 1977 has a built-in Gard-Site Smoke Detector model 081-612. It does not has battery. Its mounted on the...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
FYI --- This is a U.S. installation. I'm replacing a three way switch (the UK might more sensibly call it a two way switch??) with a Kasa Smart...
