Discuss What type of RCD is this? in the Australia area at ElectriciansForums.net
S
sivoodoo
3227898379
Pictures
Any ideas? This is a picture the customer sent me so I aint had a propper look yet.
I need to put in a shower circuit and was going to split the tails (Henley block) and fit a shower consumer unit with 30ma rcd.
Could I put the shower unit after the RCD pictured.
Yes there is a spare way on the pic but this has now been used.
It should have the rating and hopefully a BS number on it and that would give some idea.
Is the install a TT? It may be the old VOLCB in which case, it needs renewing.
Only guessing mind.
If you are installing a shower then maybe the best way to go would be to do as you suggested, bearing in mind that you still need to make sure all earthing arrangements are satisfactory.
Replace with stand alone RCD in an enclosure, similar to whats fitted in the CU's nowadays.
Make sure the rating is sufficient for the load.
You can get them in 40, 63, 80amp etc, at 30mA.
3227898379
Pictures
can't make it out but it looks like a 4 module current operated rcd.If its 30ma and you wanted to provide descrimination you would be best taking your new rcd/shower unit supply from the line side of it.
I'd go with a board change, can't see alot of space for a shower CU in that cupboard! And if they wan't something else added in the future a 10way twin rcd board would make it easy!
Reply to What type of RCD is this? in the Australia area at ElectriciansForums.net
i have faild napit annual assessment with silly mistake of using on consumer unit type AC rcd instead of Type A rcd. i bought type A rcd but they...
Hi guys. I was wondering what size cable and braker I'd need for an electric shower. Just out of intrest am I close in guessing as follows: The...
Hi, I'm back in the electrical game after 9 years break so feeling a little rusty! I'm adding an additional socket to a circuit but the main RCD...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
Hello, I was looking at installing a SPD into an existing split load RCD BG consumer unit. In the instructions for the SPD it states that it may...
