G
Guest 004
This is a 2 way 2 gang dimmer switch, which has feed in/out, and 2 switched lives and neutrals. So 4 neutrals blocked in a connector block, which was then put behind the switch as there was no room inside (only a 25 mm back box used), and the feeds had to blocked as 'the installer' could not get 3 cables into the terminal. Thus resulting in 4 feeds in another block. Resulting in the switch not being able to go back because of the depth if the dimmers !!!
Yeah these new wiring methods are great !!! Lol
FAIL!!!!
Not signing the test sheet
FAIL!!!!
