Discuss Where can I get some of these? in the UK Electrical Forum area at ElectriciansForums.net
sythai
Hi Chaps
Been googling away but can't find what I'm looking for :-(
I'm hoping someone could advise please, ideally online somewhere?
I've eventually run out of my supply of P-clip/ loops 'not too sure of the technical name.'
(should be a jpeg attached. hopefully it worked)
My local wholesaler doesn't stock theses any more.
Can find them but not the sizes I have, can only find smaller.
Large one 50mm diameter
Small one 30mm diameter
Cheers Sy
Thanks Chaps... it's the 50mm one I'm really struggling with. Did try cable craft but too small and the other rubber ones are too expensive, need to buy in bag of x50 or x100.
Don't have the bag they came in unfortunately, use them for supporting cables when we have a quite a few running together e.g. main route back to CU (this is for domestic use.)
Very posh..:grinning: Would do if was on show, this is for a quick an easy above ceiling out of sight type of thing
Is that necessary ? I thought the fabric of the building supporting a cable negated the need for other non combustible cable supports ?
Sorry Andy I'll take that back... no offence meant ! Still getting used of the new reg (521.11.201) all round band could be an option then.
I didn't mean that the comment was unnecessary, the metal clips ! lol
What I meant was that metal supports required by 521.11.201 are not required when the cables are supported by the non combustible plasterboard.
At least that's my understanding of it. I might be wrong.
Ah I'm with you now....Only time I've only used metal supports so far was when we wired a communal stairway in PVC mini trunking (which was a bit of a pain really.)
I think Andy78 is correct in the thought that in a domestic installation cables above a non combustable plasterboard ceiling would not need metal fixings but it is your design and there is nothing wrong with it however as been pointed out you can acheive the same by using banding it it more economically priced and readily available from all good wholesalers
Reply to Where can I get some of these? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got an antique light fitting that for some reason she wants putting up (can't say I love it haha) however it didn't come with any...
Greetings, First post here. Would be most grateful for any expertise available on this issue. I am trying to convert 2L fixtures to LEDs. They...
I am wanting some advice as someone looking to get in to the industry. Hopefully a couple of you don't mind sparing a bit of time helping me get...
Good evening ladies and gents, I'm an adult of 27 who is finally taking the plunge into the electrical industry, and from what i can see have a...
