Discuss Will automatic light switch drive dimmable LED bulb? in the Industrial Electricians' Talk area at ElectriciansForums.net
C
coopern
Hi Folks,
I use a couple of automatic light switches for when I'm away, they are fully electronic with triacs, they do not have contacts or relays. I fitted them in place of the original 2 wire wall switches, they presently switch old fashioned 60W incandescent bulbs. (To be clear the automatic light switches are not dimmer switches and are they not compatible with cfl bulbs, I tried one)
Want to know whether I can replace a 60W bulb with a dimmable LED bulb (say 10W) and whether it will still work with the automatic switch?
Cheers
Automatic light switches often have no neutral attached and power the switch by sending a small current through the resistive load of the lamp.
This is fine for incandescent lamps as they will pass a mA current without any effect, for any sort of electronic control such as in CFL and LED the current would not flow (or the lamp would actually light) and the battery in the switch would soon become flat.
Reply to Will automatic light switch drive dimmable LED bulb? in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
I have 3 pendant light fixtures with a total of 540 watts of incandescent bulbs connected to a GE electronic dimmer. The bulbs flutter from bright...
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
I purchased a chandelier from Aliexpress (China) that came with bi pin G9 LED bulbs (3W equivalent) (pic attached). I asked the seller if this...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
