Discuss Wireless light switch; any recommendations? in the UK Electrical Forum area at ElectriciansForums.net
polo1
Hi all,
used a Home Easy set up, switch and receiver, but the on/off part of the switch is not working well, often not appearing to activate the transmitter. So, I'm looking for a suitable, reasonably priced alternative. Only have to switch 150w incandescent load. The switch will be in a domestic kitchen, so ideally looks like a light switch!
Any recommendations?
TJ, fair point, but yes I did! I had spare button cells fortunately. This is a new, unused switch which I had for another job, but didn't use. It did sometimes work when I used a driver to push the on and off buttons, but with the switch cover on, totally hit and miss. The switch is on a perfectly smooth wall, so no problem there. I could buy yet another switch, but frankly was not that impressed with unit, hence looking for an alternative.
Reply to Wireless light switch; any recommendations? in the UK Electrical Forum area at ElectriciansForums.net
This is in regards to wireless light switches i posted to two other forums. Surely someone here has some experience with the switches that is...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Just need some advice on this one - i wont be doing the work myself - but wanted to understand what could be done in my situation without chasing...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
