Discuss Wiring a table lamp direct to a mains light switch? in the DIY Electrical Advice area at ElectriciansForums.net
My thoughts were to connect the brown wire from the lamp directly to the plug and wire the blue wire to chocy block?How are you intending to connect it to the circuit.
Only if it is possible and safe?You intend to connect the table lamp flex direct to the light switch?
The cable is coming down the wall in conduit not chased in the wall so was going to thread it through the top?How will you get the flex into the light switch?
Reply to Wiring a table lamp direct to a mains light switch? in the DIY Electrical Advice area at ElectriciansForums.net
