Discuss Wiring Central Heating in the Central Heating Systems area at ElectriciansForums.net
R
rodders986
Hi everyone,
I've just popped over from the plumbers forum so take it easy on me...
Could anyone give me a ball park figure to wire up a combi boiler, single channel programmer + wireless room stat in a medium sized 3 bedroom house including earthing to the gas meter + cold water stop tap, including materials. Boiler located in kitchen.
Just an idea would be great, I've just set my self up after being made redundant and I know its hard to estimate without seeing the job but just an idea would be great. By the way I'm in the midlands.
as you say, difficult without knowing hoew much of a job the bonding is. that could take 2 hours or all day depending on the run. imago's in brum. he might be able to help.
Reply to Wiring Central Heating in the Central Heating Systems area at ElectriciansForums.net
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
