I'm installing downlights in a kitchen refurbishment. How can I link the lights, the switch and the mains without using a junction box because, when finished, all this will be in the ceiling void space and inaccessible. There must be some sort of in-line connector that would equate to a ceiling rose, or am I looking at terminal-block connectors in a suitable container?
You can get little plug/socket designed to be small enough to go through the downlights hole.
the lights are wired in a radial fashion. Not a central jb out to each fitting
I use these just leave a fair bit of cable length so that you can get the box out the hole afterwards.
Milton Keynes
United Kingdom
Retired Electrician
Wiring downlights without junction boxes
UK
ukdave,
ChrisElectrical88,
