Hi All,
I am about to wire 6 x 5A lighting sockets, via a switch next to the door into a living room. I was wondering if there is any reason why I shouldn’t run the switched feed around the perimeter of the loft, above the walls where the socket outlets are going to be fitted, and spur off this feed, down to each outlet? I for the life of me can’t see a problem with it, but somethings nagging at me.
Any advice would be welcome.
what ,to blow your self up .
Hi Kuffs,
It's probably best to say if you are an electrician or DIY. If you mention that you are DIY then you may/will probably get some advice rather than the comments above. However, I personally don't give out DIY advice as I see it causing more harm than good in the long run, so my advice when a question like this is asked is to always get an electrician in.
The house is my own property. I am in the middle of a serious refurb. I am rewiring as I go. It is a bungalow and I have stripped all of the plaster board of the walls in order to insulate the place. The roof above the area where the drops are going is a major PIA. I am running all the cables above the insulation. I'm also running the cables right through the centre of the loft, heigh up on battens. I want this all clearly marked and easily accessible. Quite honestly, I was just saving trying to save cable, and as the junction boxes are easy to access, It seemed to be a reasonable Idea. My question though, was can anyone see any issue with this?
Murdoch. I think my last reply may have crossed with yours. As you can see they will be accessible. Also they are done using Wago connectors and boxes. They don't need to be accessible, but I'm making them accessible anyway.
Hi Baddegg, Thanks for that, it's a fair point. Thank you for you considered reply. I was originally going to loop it but as I said, I felt it would be easier to do what I was suggesting. It's hard to explain why I want to do it this way, but you need to see the space I have to work in to have a clearer Idea. The insulation isn't an issue, as I removed it before I got started. The old electrics were in a dire state, and bordering on dangerous. The old guy that owned the place before we took it on had made some interesting mod's to some of the circuits.
Wiltshire
Wiring of 5A lighting sockets
Lighting Forum
Thread Tags
Kuffs,
KeenPensioner,
