Discuss wiring under cabinet strip lights supply or load in the UK Electrical Forum area at ElectriciansForums.net
hi
Wonder if anyone could give me a bit of advice. I have taken out my old fluorescent lights from under my cabinets and I'm replacing them with low wattage led strip lights. I have 2 in total. I have my mains supply cable which comes from my Light Switch and this cable runs to under my first kitchen cabinet. I am just going to join my first strip light with an unswitched connection unit. The Supply terminal connecting with the Light switch and the Load terminal to my strip light. I then need to connect a second length of cable running from the connection unit so that I can wire light number 2. Was just wondering do I double up the wires from the "Supply" or "Load" side from my original connection unit? When I think about it, it looks like either but thought I better check. Thanks very much if anyone can give me any advice
If I follow your description, you put both lights on the LOAD side of the connection unit and the feed from the light switch on SUPPLY.
Sometimes these connectionunits have a neon indicator on them connected to load, if it was wired in reverse, the neon would be lit all the time.
Please isolate circuit before connecting.... not just off at the light switch.
Hi again, sorry for being a pain, littlespark has answered this but I just wanted to post a picture and double check in case I hadn't explained it right earlier. This is the junction box under my kitchen cabinet. It was wired like this when I moved into my house but I want to wire it into an unswitched fused connection unit and then onto a second unswitched FCU. Do I double up the "cable leading to FCU number 2" on the Supply or Load side. On the pic below it's wired together on the supply side of the terminal block. Or does it really matter? Thank you all once again
I'm not sure why you are using 2 separate fused connection units, but I may have misunderstood.
I ensure the cable sheaths are inside the junction box, and provide strain relief for the cables. You may already be going to do this, I can see it's work in progress.
Is this fed from the kitchen (or another) lighting circuit on a 6A mcb? If so, why bother with adding extra fuses in series, as unless you fit 3A fuses they won't have any benefit.
Hi DPG and Timbo. It's not work in progress, that's what it like as I find it. I really just want to tidy it up and make sure it's safe. Everything works fine as it is. It's just that the wires seem to hanging out of the chockbox and I just feel that it would be better wired into a connection unit of some sort with the cables hidden and restrained. I wouldn't think it would be a job for an electrician as I am just trying to put it into something more substantial. Just thought it would be better with a fused connection unit. I wouldn't think it really needs fused. My electrician has recently installed a brand new MK Consumer Unit with RCD protection. Thanks very much
If you want to just tidy up a little then you can't go far wrong with a flex connection plate and a surface patress.
https://www.NoLinkingToThis/p/mk-logic-plus-1-gang-20a-flex-outlet-plate-white/70006
That's great Strima/Timbo, that would just do the trick. Can I just go back to my earlier query above and clarify whether I should use the "Load" or"suppy" to double up the cable for the 2nd connection plate. Or does it really matter? Thanks again
SUPPLY
Hi anthony, thanks for your repy, it just confuses me because in post number 2 it is mentioned that I double up the "Load". I kind of think it doesn't matter but I'm not 100% sure. Cheers
Flex to light in load at each connection unit fit 3A fuse. Secure/clip cables and flex. And before you use clips and screws make sure they are too long and won't go through the unit (learnt hard way).
It may sound funny but when you are an apprentice sometimes you learn the hard way I wouldn't like to know the OP has screwed his connection unit into his Royal Doulton.
Cheers. Flex to light in load at each connection unit fit 3A fuse. Yea I agree with that. On both connections units I use "load" for the flex going to my lights. I have my "Supply" in unit 1 but I also I need to extend my "supply" to connection unit 2. So am I doubling up on the "Supply" or "Load" terminals on connection unit 1 when taking the cable across to unit 2. Cheers
Sounds like you have got there.
If you are using two fused connection units the supply goes to SUPPLY of each FCU. The lights are the load for each one.
If you are using junction boxes or flex outlet plates there is no difference between supply or load as there is no fuse to consider.
Thanks very much Richard for the clear explanation and diagrams.
Reply to wiring under cabinet strip lights supply or load in the UK Electrical Forum area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
Hi all, I'm looking at putting some warm white LED strip (3000k) in aluminium profile under some kitchen cabinets, so just looking for...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
