Discuss Wiring up garage lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Joe
Hi I'm new to this forum but am hoping for some advice on wiring for my garage.
Ive recently built a new garage at the bottom of the garden and have run 30m of 6mm swa from the house to a new consumer unit in the garage to power 2 florescent lights from a 6a MCB, a 13a socket from a 16a MCB and a 16a socket from a 20a MCB. Everything is correctly terminated and works properly.
However, I'd now like to add a switch to the lighting circuit rather than using the consumer unit to switch on and off. I have bought a 1 way outdoor switch for this circuit but believe I will need to add a ceiling rose/ junction box to avoid a short circuit. Please can someone look at my wiring diagram to let me know if they think it works. Is this the simplest option? Also would wiring like this pass regulations; I'm doing the work but will need this signed off by a spark when I'm finished.
Many thanks in advance.
Joe
that willl work, but you need to get your tame electrician to test before energising.do not power up before he's done the dead testing.
Out of curiosity, why an outdoor switch? Why not just put a switch inside the garage?
Are there any extraneous conductive parts in your garage?
Also, as above, any RCD protection?
Joe
Hi Joe
If it's already wired and the switch is an addition, you could just wire your new switch back to the CU and do your connection in there.
Hi Joe
Failing any of the above you could get an Electrician to do the job properly, supply all the relevant certification etc.
I dont think anyone who asks q's on here wants an electrician or certification.
If that is the case why is everyone offering advice when we all know what is required certificate wise, and the rule of the Forum regarding offering advice to What appears to be a DIY job. Should got the job done by a professional in the first place, of course if the OP says he is an Electrician, then he should give up, or get a new career.
He is saying he wants a spark to sign it off at the end. He can use the Part P 3rd party sign off for that. Spark can inspect and test it and charge handsomely for it. If anything is amiss they can charge redo it or OP can redo it himself and the spark can charge again to inspect and test again until they are happy. 3rd party sign off is not cheap.
He is saying he wants a spark to sign it off at the end. He can use the Part P 3rd party sign off for that. Someone can inspect and test it and charge handsomely for it. If anything is amiss they can charge redo it or OP can redo it himself and the spark can charge again to inspect and test again until they are happy. 3rd party sign off is not cheap.
Like I said TJ should have got the job done right in the first place. People froging about with electrics when they don't know what they are doing is a recipe for danger and unnecessary expense.
He's an adult and that's his decision what he chooses to do. The job may well be satisfactory. The spark who tests and inspects it will decide that.
I know what you're saying, but he only asked about a light switch lol. Why do we have to consider his whole install and certification? Someone is gonna ask about him "exporting" something in a minute hahaha :)
TJ, the OP did the entire install
Part P, inspection and testing?
Insurance not paying out ..............................
Could be a very expensive "saving" the OP is trying to make.
If some one will take the test and inspect on, if the OP is taking that tack the the Person that's going to do the testing should have been involved from the outset of the job.
Valid point Pete, if 3rd party should be inspected at each stage. But I'm guessing that it is all clipped direct surface etc. and all could be inspected in one visit.
Reply to Wiring up garage lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
