This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
Evening all.
Getting a little confused with regards the wiring for a Y plan when there is no controller to wire to (an internal programmer is being fitted).
Since the main feed is wired into the boiler, then a switched live, switched neutral and boiler demand is taken to the wiring centre (no HW on or CH on), where do the orange, white and grey from the 3 port terminate to?
Any help would be appreciated!
they dont a 40 cdi is a combi boiler and a y plan system is for a heat only boiler......
contact me via pm if you need more help.
Thanks prest,
Looks like I've got the model no. wrong as it is definately a floor standing system boiler. Been on to tech help and they say you cannot have internal programmer so I think the heating engineer might have made a mistake.
I'll find out later.
