Discuss Working for B&Q in the UK Electrical Forum area at ElectriciansForums.net
I've done installs for bodge it and quit for over a year now. The install schedule rarely matches the work to be done, which in some instances can cause friction with the customer. It has gotten worse since the fitters became responsible for the pre-fit survey. They miss loads. It wasn't nearly as bad when they had a dedicated survey team, in fact it was fine. I've trained one of the fitters that I support to send me photos of cu, meter etc and ring me if he isn't sure. Tother fitter hasn't yet grasped the importance of this but is happy to pay for work he misses out of his own pocket. They're both good guys and I would have them fit a bathroom for me anytime, but in there private capacity and not at bodge it and quits inflated prices. Its occasionally frustrating but in the main okay. As regards the woes some have had with being approved by bodge it and quit i only needed a crb, now called a dbs. Probs different for none napit folk as they don't already have your documentary bits and bobs on file. Its work at the end of the day and maybe I'm lucky with the guys I support. PM me if you need more info but nobody gets rich on their work.
Rob
well cut his training short wont you....as once he`s had 5 weeks of it he`ll think he`s an electrician...
trust me...we`v all seen it...
Reply to Working for B&Q in the UK Electrical Forum area at ElectriciansForums.net
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Just had a simple kitchen light not working job, one of the fittings with the 4 spotlights on it. Took the fitting down to check if there was...
This drives me round the twist, the client tells you what they want, kind of. you do the work the way the client asks you to and then when its all...
