G
Guest55
my lawyer instructs me to say "no comment"
Hi, so cutting and re-sealing is the way forward as it's an urgent job
There are ways to do this safely but in asking the question you show that you are not competent to do so (no offense meant), like others I will not discuss the correct procedures over a forum as at your level of experience and training you must follow the safe isolation root which can only be done legally by contacting your energy provider and getting them to assist in the power down.
This sight is to give good legal advice so try not to pull us for doing just that - you teach your kids to use Pelican crossings safely and would never tell them to cross the road between parked cars for obvious reasons yet we all do it because we are aware of the risks and look for them but not advisable to teach a child this.....kinda the same thing, so cannot advise you further than already has been.
right if you cannot get the DNO out which can be difficult when you need them ,then cut the fuse seals so you can give yourself safe isolation then install a double pole switch, the wylex ones most electricity suppliers use are available from TLC £18 ,then put fuse back in and seal the fuse then you can work on relocating the board with out killing yourself , oh and by the way , as we have to use safe isolation we can pull a main fuse but never the meter seals and that came from one of Scottish power 's bosses
no matter how much we say dont do it, some people will ignore all advice and do it.Don't forget the law is slightly different in Scotland regarding this so he may be speaking of his knowledge about local regulation, in Scotland I believe you can notify or even take a short course to allow you to do your own resealing.
This is not the case for the rest of us, again as a forum we should be giving legal methods and safe methods, the OP may be competent enough to do a live swap as some have advised as but the next guy reading it for the same answers may be the one one kills himself because he has little or no electrical knowledge but it said it on here, how to do it.
surely its better for all to say best to get the dno out to isolate or pull the main fuse if it looks in good condition
as a last resort do such and such so its safe
