Darkwood
That was the fastest Sticky Thread in history! This should be fun for all of us. (ps I like your rules DW)
This is a house I was working on today, came across this. One word describes it,,,,,, FAIL
Just after taking that I knock a full box of washers and screws behind the cooker and had to pull it out to get them. Needed them or would not have bothered.
Great thread, post them pictures up lads.
this had been arcing for a while in a pub, couldnt have that i shuffled some circuits around to get the pumps back on in the pub.
wouldnt bother me, ill drink ale,bitter,lager or cider
Not electrical but still made me chuckle this was a builders handy work who was doing a few jobs while I was doing some electrical jobs,
Spot the mistake!!
door handle wrong way around
someone annoyed there neighbor XD
Temporary power, installed by the builder!
What the hell did they use to hold it up in the first place? Bluetack
(sorted out the pics for you btw Guv)
Had their rep come down to sell their wares and all looked good but the product codes were wrong with what they demonstrated. they stated one code was rated at 40k per fixing when it was actually 20k. the fixing had a part that clips through unistrut (now known as the weak link) under load it just pulled through and once one had gone there was no stopping the rest running away. The 40k version actually just omits the unistrut clip and the wire is just sleeved and looped through a hole.
It is not even carrying that much weight by the looks of it. A lot more cables to be installed going by the amount of basket and tray. Thank god it happened when it was still a building site and not a functional building!
Reactions: Megawatt
Definitely, imagine if it was fully loaded, it was only having a suspended ceiling below it and that was the main exit route with a lot of foot traffic planned and it came down on them, Big claims#!!!!!!!!
Reactions: Megawatt
That could have turned out to be the biggest cause of electrical death whilst exiting a building the UK has ever seen. Hope that company gets their nuts and bolts sorted out for the next project.
This is what happens when a welder doesn't have his return clamped properly and the 400amps uses the turn table supply earth to return on.... note how its burnt out in its twisted core design.
This is why welding is a massive danger to the integrity of the buildings circuit and equipotential bonding... it can destroy the earth to many circuits leaving them live and exposed in some cases. Many a death has been attributed to poor welding set-ups of the years.
what type of fixing was it?
usually for us its raw bolted unistrut to ceiling then everything else hangs off that
It was a product called zipclip. Basically you still a 6mm hole, then you have an eye bolt basically that you just bang in which none had failed then the wire comes off that
Reactions: daniel sinclair
At a secondary school, this is a MCB which has been siliconed onto the side of a dimmer unit enclosure. I spotted this within a month of the dimmer unit going in but all of a sudden everyone involved, from contractor to site service manager to governors suddenly turned into the three wise monkeys. They didn’t feel too clever though when the application for the entertainments licence was turned down because of it, and they had to cancel the show for which all the tickets had already been sold.
ImageUploadedByTapatalk1427235728.588181.jpgImageUploadedByTapatalk1427235777.724189.jpgImageUploadedByTapatalk1427235807.014364.jpg
The first two are from when i used to follow plumbers around, good little earner that was.
The third one, well i just like the pipework
Reactions: 2 people
ImageUploadedByTapatalk1427236648.326585.jpgImageUploadedByTapatalk1427236699.991276.jpg
Another skilfully completed job (in the eyes of a plumber)
Oh i forgot to add, hope that fuse never needs changing, or the spur inspecting in an eicr. (Just to clarify, i did move the spur and all associated wiring, and all the temp connections were already made when i arrived, because he wanted it tested so he could wrap up) i just laughed, then politely asked him to remove the boiler so i could access the spur.
that was left after builder crew doing new kitchen and downstairs work.
they had someone for new kitchen, and told the customer she needs another spark for big rewiring.
in the meanwhile reconnected it with some new cable,
fair choice from them and some work for me :-)
8K
Darkwood,
mainline,
