N
Nuvo
can anyone recommend me a decent wired alarm for my own house. been looking at texecom and honeywell advice is appreciated
Funny, I am looking one myself. Just a basic one. 3 pir's and a couple of door contacts. So far I've only purchased the cable! Lol. I'm running a 6 core to each piece of equipment and doing the connections at the panel. Don't know what to go for so will keep an eye on this thread.
I`m pro Texecom......2 good versions , Veritas excel, excellent 8 zone with area text, or premier if you need full all dancing system upto 640 zones
Texecom, fitted loads never had a problem, go with hard wired, make sure you fit Texecom Mirage DT PIR's more expensive but very few false alarms, buy cheap buy twice!
Same here, used them for donkey's years .Fit and forget.
Haha ive done the same. Just bought 6 core cable. Looks like its going to be texecom.
i'd be wary of some of this alarm cable that's available these days. i've seen thicker spider web. it's so thin, it's pathetic.
Apart from the power cables, Texecom run alarm and tamper circuits down 2 cables only. So if you use Texecom pir`s, the will come with the eol resistors built in making installation simple.
There is so much copper clad stuff around these days it is getting harder to get decent alarm cable
are the texecom veritas plus anygood or just get the premier range
Your choice is dependent on what size system you need and whether you need the functions of the premier panels for the small domestic systems I use the Veritas Excel and had no problems
Nuvo,
tazz,
