S
SparkB
I have been asked to 'earth' a metal/stainless steel bench inside a workshop.
The bench is used with hand tools and power tools - there is a socket directly above it where power tools being used are plugged in to.
Also staff are complaining of receiving static shocks when touching the bench, and hopefully the earthing would help with this also.
My thought is to earth the bench via 6mm Green/Yellow to the earth at the socket (metal clad socket).
I have had a few conflicting views on this so just wanted anyone's thoughts?
I'd suggest finding the fault (probably more than one fault) that's giving the tingling shocks would be the highest priority. Also ramp test the RCD that protects the sockets and if there isn't an RCD then consider installing one.
Hi Marvo, There is no fault present, the staff are getting static shocks when touching the workbench after walking across the room due to new flooring - no electrical appliances involved when the static shocks are felt.
The request to earth the bench is to try and alleviate the static shocks.
Hi Yellowvanman, Thanks for your reply. I realise that there is no actual requirement to earth the bench, but if it's requested and alleviates the issue with the static then I cannot see a problem but wanted to get others views on it
Hi Ruston, thanks for your reply. The issue with static has only been present since the new flooring was fitted - despite staff wearing anti-static soled safety shoes etc. They asked for bench earthing as a hopefully quick solution
If the Staff are discharging static to the bench it must already be Earthed / Bonded to earth.
Have you checked.?
If it isn't then the static must be in the bench and discharging to them.
Unless of course there's a fault on an appliance lead and the bench is live and static is not the problem.
Or they're all wearing nylon underwear because it's hot.
Hi Snowhead, thanks for the reply. The bench definitely isn't earthed, and like I say even when no appliances are in use and stored elsewhere staff still get a small shock
What type of flooring is it? If they're wearing anti-static shoes then there's a very high chance it's not static.
You'll have to forgive me for being skeptical, I'd still suggest test the bench with a wander lead for elevated voltage wrt earth and impedance to earth and just for good measure test the socket circuit as well. There's many times a low insulation fault has been mistaken for static and even on the slim chance it is static, earthing the table will just make the shocks worse.
The bench isn't fixed or secured to the floor or walls it's just like a large metal table, freestanding.
When I was there I felt the shock too - a small quick sensation, just like static, that was over in an instant
Thanks for the replies everyone
I kept getting one helluva belt off the missus car the other week, but not her, I started closing the door with my foot but one day when we got back, I steadied myself against the wall and got a belt off that! It must have been something building up in my clothing, as it only happens when I am wearing one particular top.
I remember another thread about someone getting a belt from radiators, but it turned out that they were feeling the static discharge TO the radiator that they had built up.
In my opinion, if the feeling is fleeting, but painful and no voltage is apparent during testing, then further earthing the bench will only enhance the sensation?
I presume the bench is not earthed now i.e. there is a very high resistance between it and earth, such as if it stands on plastic feet or a dry plastic floor. If they are getting shocks when touching it specifically after walking across the floor, it must be the people getting charged and then discharging themselves to the stray capacitance of the bench when they touch it. If that is the case, then neither a resistive connection to earth nor a solid bond will prevent the shocks as the stray capacitance will still be there, it could make them worse as the bench will discharge faster through the bond.
The only situation in which a 1MΩ earth strap on the bench would help is if it is the bench charging up, e.g. if there was compressed air / powder handling equipment on it generating a triboelectric charge, and then shocking the people.
It sounds like the floor needs treatment.
Thanks for the replies everyone.
Lucien, your theory is how I see it also - however I am not sure how or if the floor could be treated - it's probably not fit for purpose in the environment it is in - I have told them this may be the case.
I have tested the bench etc and have now bonded the steel table leg with 6mm Green/Yellow to the earth at the SWA banjo on the socket above.
Staff say this is immediately better, with reduced static being felt - though not a total solution
before bonding the table, i would have used a voltmeter to determine whether there was a potential wrt earth on the table.
If staff are getting a static charge built up on them from the man-made material of the floor, and then touching the bench and discharging this static charge, then earthing the bench can't improve the situation as far as I can see. The best way to avoid the effect is to touch the bench via a resistance first (as Sean mentions above). There used to be a product available in the form of a resistive self-adhesive pad which was fixed to metal objects (primarily filing cabinets in offices which are carpeted) - the user touches this briefly to discharge the static charge in a controlled way, then they will not feel anything when they touch the metal object. Daz
I will look into these discharge pads as a possible suggestion.
As I say staff say the static is less so since I did the connection to earth, strange I know.
Dont think increasing the humidity is an option due to the work they do.
All this due to some new flooring eh!
Change the bench is an option to a plastic one or some other type ?
That's OK until they touch something else made of metal like a cupboard or a power tool :-)
This all reminds me of how I always used to get a static shock off car doors when I got out of the car - sometimes quite a powerful one. I never do now though because I know how to avoid it :-) Daz
Earthing Stainless Steel Bench?
SparkB,
DPG,
