G
That's the only reason mate, Because it was the first post in the thread I couldn't delete the image without deleting the whole thread.My last thread was taken down due to copyright reasons, I think it was because I scanned a page from the wiring regs and posted it.
Can anyone tell me if this circuit design conforms to regs?
Will this alteration be getting tested and a certificate produced ?
Nope alterations and additions do not need to be notified to building control so no certificate needed
The wiring regulations stipulate that all alterations are tested and certificated with the appropriate series of tests to verify safety. This is regardless of any need to notify work or not.
Thank you for pointing that out. The wiring regulations are only advisory. I will take your comment into consideration. My main concern at the moment is getting the design correct![]()
Design is just advisory, crack on.
I want the design to be safe, so I have decided to design it in accordance with BS7671 wiring regulations, my problem is I am not sure if this design conforms so I elected to consult the experts in this forum.
If you really wanted it to be safe you would consider that testing of the circuit is the only real way to prove it will function without risk to life or property.
I'm not being obstructive here but you really need to be honest with the forum in order to get on. You have not filled in any of your profile so nobody knows your qualification level or work. I feel that you are a DIYer doing up your own home with no electrical qualifications. Am I correct ?
Mate, if you want advice and help on this forum best you take good advice and use it - if you don't then we can only assume you go to work on a horse
You are correct. I am being honest, why do you think otherwise?
