G
Gigsy
My mistake, that is showing you how to secure the cable in the cable grip
Thank you, I know, I started the threadSince you started another thread on this its been answered there 4 cables max
Hager J803 - http://www.electriciansforums.co.uk/threads/hager-j803.117059/#post-1222878
?Gigsy can you stick to one thread please it just causes confusion
Decide which one you want and the other one can get deleted
Yes I have, but you didn't mention that on your 1st post if I recall corectlyThey are push fit connectors with cable grips, so evidently yes they are in a suitable maintenance free box!!
Have you never heard of a J803?
I assume that you are adding 3 extra sockets to the circuit,why don't you install them on the ring.Even how well installed I would try to avoid using j.b's even MF ones under floors.
If you need to ask then I'd (respectfully) suggest you shouldn't be doing electrical work. The suggestion that an EIC or MWIC is dictated by Building Regs is wrong. The two are separate entities. If you do an alteration, addition or new installation you complete the appropriate certificate. Building notification is a separate issue.What a preposterous comment to make!
You're the cable chased across the ceiling bod.You don't have a clue m8, I am talking about the law. If you alter or add to a circuit there is no stipulation in law that you have to test the circuit, end of!
What Law are you talking of Gigsy?You don't have a clue m8, I am talking about the law. If you alter or add to a circuit there is no stipulation in law that you have to test the circuit, end of!
