O
Octopus
Need to do a switch fuse install and I was wondering which products people prefer ........
Needs to be metal as the sub main is going to be SWA
A 3 gang light switch distributes power from one source to 3 separate destinations.
Some light switches have on/off, dimmer control and a fuse.
Yes a light switch can be considered similar switchgear assemblies to that of a consumer unit made up of OCPD rcds and the like........
Give over!!
421.1.201 Within domestic (household) premises, consumer units and similar switchgear assemblies shall comply with BS EN 61439-3
Similar switchgear assemblies
The phrase ‘similar switchgear assemblies’ in Regulation 421.1.201 means those assemblies used for the same fundamental application as a consumer unit. A consumer unit is defined in Part 2 of BS 7671:
If you wish to compare a consumer unit to a light switch then be my guest!
What goes on in people’s heads who think that, god only knows and is quite worrying.
Give over!!
I think its a have :D
‘Consumer unit(may also be known as a consumer control unit or electricity control unit). A particular type of distribution board comprising a type-tested co-ordinated assembly for the control and distribution of electrical energy, principally in domestic premises, incorporating manual means of double-pole isolation on the incoming circuit(s) and an assembly of one or more fuses, circuit-breakers, residual current operated devices or signalling and other devices proven during the type-test of the assembly as suitable for such use.’
Give over!!
Ok forget about light switches, how about SFCUs?
Many SFCUs have double pole switching and they have a fuse.
Some have a fuse and an RCD.
Part 2 defines a fused connection unit as a device associated with the fixed wiring of an installation by which appliances may be connected,and having provision for a replaceable cartridge fuse link.
Made to an entirely completely different British standard.
Switch fuse - metal clad recommendations
Octopus,
Ian1981,
