Discuss Electrical safety certificate and downlights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for the reply. It's a rented property. It didn't fail the last check 3 years ago so I'm suspicious it shouldn't need to be updated.They do not need replacing. Like many urban myths, there is no requirement to fit fire-rated downlights, anywhere, unless the ceiling (that you have turned into a swiss cheese) is a fire-rated ceiling.
Fire-rated ceilings are only commonly found between purpose-built apartments and in places like the ceilings of integrated garages.
PS What sort of "safety" certificate are you after, and why do you need it?
I'm the landlord of the propertyAre you the owner or spark?
That was essentially my understanding from reading around too although I suspect I would fit fire rated if I were replacing them anyway.@Midwest I’m hoping that’s a serious question?
You should know that Plasterboard will provide a degree of fire protection....
The electrician said he needs to replace all of them before he can issue the certificate so I have no code at this point. I'm not sure what you mean about the reg number in this context?Have you got a new EICR with a C2 against these lights?
If so please go back and ask for the reg number to back up the decision
Can you please answer this question^^^^^^^^^^^^^^^^^^^^^^They do not need replacing. Like many urban myths, there is no requirement to fit fire-rated downlights, anywhere, unless the ceiling (that you have turned into a swiss cheese) is a fire-rated ceiling.
The certificate is not required, but as its a rented property I like to know there isn't something lurking in there.Can you please answer this question^^^^^^^^^^^^^^^^^^^^^^
That's very helpful - thank you bothWhat @Murdoch is getting at is your electrician can't just say "he needs to replace all of them before he can issue the certificate" unless he specifies what electrical regulation the original lights are not complying with. This will have a regulation number.
As @Murdoch says, email your electrician and get them to explain why they all need replacing and what electrical regulation they are going against. State that you would like the reply in an email so that you have written proof of this conversation.
18Out of interest, how many down lights (non fire-rated) do you have?
No gas is required but electrical is optionalI thought Electrical Installation Condition Reports were required for properties that are rented out?
Yes. £50+vat per lightHave you been given a quotation for the replacements (fire-rated)?
He's having a laugh. Thats £1300 for something that doesn't need doing.Yes. £50+vat per light
That's a good question. The managing agent organised it but I believe its a "report". I have emailed them for the details of the regulation they are concerned about.He's having a laugh. Thats £1300 for something that doesn't need doing.
You haven't said what "certificate" you have asked for.
If it is an EICR (note that the R stands for REPORT, not CERTIFICATE)
An EICR only reports on the installation and where there are deviations from BS7671 (The Wiring Regulations).
So, as above, if he states a non-compliance, then he must state the BS7671 regulation that it contravenes. And there isn't one.
That's a very valid point, they are standard halogen bulbs. That isn't what they said in the initial email though. I will get more clarification.It could be that the existing downlight has thermal damage from excessive heat from the halogen lamps. What sort of lamps have you got fitted at present?
I have a feeling he thinks I was born yesterdayfor £50/light i'd fit integrated JCC V50 's . selectable colour temp and IP rated for bathroom zone 1 and 2.
If they are halogen then the heat produced is around 200 degrees C and could be a source of ignition if they are installed next to a joist or something combustible. Seen this so many times. reminds me when I was a Q.S. and the electrician drilled out part of a joist to get this halogen downlight in "well it's fire rated isn't it".That's a very valid point, they are standard halogen bulbs. That isn't what they said in the initial email though. I will get more clarification.
Bite the bullet and get an EICR doneThe certificate is not required, but as its a rented property I like to know there isn't something lurking in there.
I completely agree and the electrician has been in to do it. My point is should I need to replace all these lights to get a pass when I have never had a problem before.Bite the bullet and get an EICR done
What did the Electrician say on the EICR, did the EICR prove to be a Satisfactory Report? If the Electrician has noted any dicrepencies then as you are the LandLord it's down to you to get them put rightI completely agree and the electrician has been in to do it. My point is should I need to replace all these lights to get a pass when I have never had a problem before.
I didn't actually ask for anything. The agent prompted me that it had been 3 years since the last "which ever it is" and suggested organising it again so I am only guessing if its a report or a certificate. I didn't know there were two possibilities.Looks like the electrician or agency the OP has gone through are trying a fast one.
OP: Please clarify. First it wasn't a report and now it is... What did you actually ask the agency for? an EICR?
Get the EICR completed and take it from there Mate, read the Best practice guide I posted to you, you should also talk to your insurance company, to sassertainwhat, legally is required of you, as a LandLord, it does nobody any good walking about with their eyes shut, thingking they have done what is required of them. If you think you have already had an EICR done, let the Forum see a copy, shouldn't be to difficult to scan and post, doing this will enable the Forum to offer any advice that is relevant.I didn't actually ask for anything. The agent prompted me that it had been 3 years since the last "which ever it is" and suggested organising it again so I am only guessing if its a report or a certificate. I didn't know there were two possibilities.
yeah. £50 /fitting is steep unless he fits decent integrated downlights. the ones i mentioned are these:
JCC V50 Selectable Warm White / Cool White Dimmable LED Downlight JC1001/NB | RS Electrical Supplies - https://www.rselectricalsupplies.co.uk/jcc-v50-selectable-warm-white-cool-white-dimmable-led-downlight-jc1001nb_12016
nope. i just like them.Have you got shares in JCC, seem to be mentioning them a lot
Yes everyone has been very helpful - thank you.Me thinks the OP has got the picture now;
EICR has been defined a few times, Best Practise Guide 4 posted twice, me Guide 5, discussion on fire safety, down light recommendation & pricing. Who says we don't dish out advice for free
Maybe Tel fits them a lot and finds them a good product to install and reliable at a good price, nothing wrong with a good recommendation in this trade.Have you got shares in JCC, seem to be mentioning them a lot
who employed the electrician and were they recommended/preferred contractor by the agent.Yes everyone has been very helpful - thank you.
I will wait and see what the electrician says about the reason for replacing them and take from there. I do want to do the right thing, but not waste a lot of money doing so.
Cheers
The agent arranged everything and I don't know who it is. I don't trust the agents as far as I can throw them so that's not a good start.who employed the electrician and were they recommended/preferred contractor by the agent.
Change the Agent!The agent arranged everything and I don't know who it is. I don't trust the agents as far as I can throw them so that's not a good start.
That might just be the best advice I have heard all dayChange the Agent!
Reply to Electrical safety certificate and downlights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
