N
NathanMorgan
I’ve chased out two channels and I’ve applied bonding as a rough coat and im wondering what you all use to finish it off for a smooth joinless finish.
Would multifinish or dob and dab adhesive achieve this finish?
Is the wall being Papered or painted? if the later don't be a tight wad get it done professional.
easyfill is good because if you can't get a perfect finish, it sands easily.
OK then use some easyfilit will do the job?
Yeah. Bonding first if the chase is deep, fill it shy of the surface or cut it back once semi dry, easi fill on top, once dry rub it back with a bit of 120 grit paper, smooth it off with a pad, mist coat, fill any imperfections, mist coat again then final coat.
I rewired my house, made good all the chases and decorated. You would never know the walls have been chased....I rewired it on my tod In 6 days.
That's really good going Lee, you have to crack on when nobody's paying for the work though. :)
Filling Wall Chase............
NathanMorgan,
Risteard,
