R
rick
I’ve just got a job to install some outside lights. The plan is to run SWA the length of the garden with five lights along the wall. I was going to run the SWA up to just under each light, then use an adaptable box and connect each light fitting up with rubber flex. But I think it might look neater to keep the SWA at low-level and connect the lights with the rubber flex in conduit, so the junction boxes are less visible.
What am I am not sure about is what boxes I could use in either scenario, and whether it’s OK to do the latter option (in effect how long can the flex of the light fitting be). Really appreciate some advice as this will be my first decent job in SWA and I’m unsure of the best ways to do the junctions.
