Discuss Outside lights - SWA junction boxes in the Australia area at ElectriciansForums.net
rick
I’ve just got a job to install some outside lights. The plan is to run SWA the length of the garden with five lights along the wall. I was going to run the SWA up to just under each light, then use an adaptable box and connect each light fitting up with rubber flex. But I think it might look neater to keep the SWA at low-level and connect the lights with the rubber flex in conduit, so the junction boxes are less visible.
What am I am not sure about is what boxes I could use in either scenario, and whether it’s OK to do the latter option (in effect how long can the flex of the light fitting be). Really appreciate some advice as this will be my first decent job in SWA and I’m unsure of the best ways to do the junctions.
Install the swa at low level term in IP54 boxes , strip the armour with long enough tails to be installed within conduit up to the luminaire
thanks Bugsy, but don't quite follow, as I will have three connections in the box - SWA in, SWA out and connection to light. Also what sort of box would allow me to connect the conduit to it, and presumably need some sort of "stop end" at the top of the conduit where the cable emerges (or use another adaptable box with closed grommet???)
loop in and out of the luminaire but make off the armour ( glands ) at the low level adaptable box, run the conduit from the the adaptable box to the luminaire and run the stripped wire armour cables within the conduit to the luminaire ( what luminaires are you installing )
Terminate in angle box using wago connectors, fit a femail adaptor to the bessa box , stuffing gland and flex to the luminaire, ( to save stripping the armour back as much you could make the termination in the adaptable box
i'd have to say my preferred option when wiring lighting in swa is instead of an adaptable box use a master seal socket, make off your connections as if you were feeding a socket circuit, and wire the lights on to a 13A plug top.
This way allows individual lights to be isolated, or removed completely with out affecting the rest of the install, it also allows easier fault finding should a problem occur.
unfortunately it will add about £20 per point to the install cost.
use a galve y box armoured in and out then stuffing gland with flex to lights ,seals,lids etc, if worried about water getting in buy some resin fill the box water proof or get one of those new resin joints
I'm about to do the same job and will be using nickblake's approach. I will leave the longest tails possible inside the box so that in future years the joint block can be cut off and a new joint made if necessary.
thanks bugsy and nick, I think I've got it now, but one thing, would prefer to run plastic conduit from low-level besa box to the luminaire, to give the flex some protection, can I connect plastic conduit to the galv bessa box, and would a stuffing gland in the top of the conduit be OK or should I put an adaptable box there? final job would be something like this
| < flex to light
[ ] < box or stuffing gland
| < plastic conduit
besa-------------swa-----------
many thanks for help!
Problem you have with a conduit is water penetration you could use a bit of flexible YY cable , the one with the braide armour , its going to be tight but you can get em in just have to be very acurate with the snips
Ide do that personally if you can do it on the back of the wall even better and drill though.
A
SWA to points around the garden, then black rubber flex off to lights. If the flex is above ground you've taken care not to leave it open to damage. And I'd recommend push fit connectors
In the past I've installed 5amp round pin Lewden sockets and plugs looks very neat and tidy, as you can unstopper the top spout and have the cable running directly through the besa box. Alternatively a 3 way Prately box with both SWA terminated into it then a stuffing gland in the top spout with a bit of HI TUF to the Lewden socket :D
Reply to Outside lights - SWA junction boxes in the Australia area at ElectriciansForums.net
Hi, I do basic electrical DIY like changing light fittings and have got a light to put up that only has a fly earth and no flex earth (see pic)...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
I collect old Electrical Fittings and I recently acquired this vintage Junction Box (photos attached). I've been trying to figure out how it would...
Hi, Hopefully I haven't made an error but I was speaking with another electrician and he said standard junction boxes with screw terminals can no...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
