NICEIC Certification Scheme
If the hole is bigger then that is down to the plasterer or builder for not cutting it correctly, having a gap like I said is not an issue as long as the live terminals are not accessible or exposed when second fixed.
I get the impression this has been a bit of a rocky ride and only having one side of the story means it is difficult to give a overall view but as for the issues we can see then we can give you our professional opinion.
Maybe it is the perspective in the photo but it doesn't come across as been too big a hole but if that is the case then all that needs to be done at this stage is the section of plasterboard to be cut out and a new piece put in with a correctly side socket cutout. A deeper metal box could also be fitted but that is not really a issue tbh.
thankyou
bec
because he went onto another job, didn't prep the room properly for the plasterer to carry on. Plasterer refused to touch this wall and walked off the job. It's been like that ever since. The electrician is also the builder. The plaster board is also on an external solid wall so water vapour builds up. The plaster board wall has mould on it where the dot and dabs are.
The "Electrician" being one and the same as the builder, reinforces my suspicion that the cable isn't 2.5mm2, a suspicion may I add, to the normal builder, all cables look the same, 2.5, 1.5 after all it's Blue and Brown with an earth wire isn't it?, like I said I can't be sure, just a gut feeling that's all.
confused by statement by NICEIC that this ok? Electrician compliant as circuit not energised. Can anyone tell me how NICEIC can make statement like this and assess wiring ok when they haven been to my house to inspect
see attached the work left like this on Aug14th and I cant get it removed until somebody says it non compliant
I would have thought the Electrician did a good job but didn't know the walls would be dry lined afterwards otherwise the Electrician would have just screwed the back box to the wall, otherwise I can see nothing wrong IMO.
It is 2.5 Pete, 2.5!!
Are you saying that this is going to be left like this and covered over? if yes then it is obviously non compliant, if however it is left like this not engineered, locked off until the plastering has been done, so all OK. One point though that cable doesn't look like 2.5mm2m why because one of those cpcs looks suspiciously like it#s yellow and not G/Y Just saying.
Why is that Bob, the disagree I mean?
As far as I can tell although the cables are a little shorter than ideal I wouldn't have a problem connecting them soundly without extending, and a bit more cable could be eased into the box if really necessary. Maybe this thread should be re named Much Ado About Nothing. :rolleyes:
so we agree that the plaster board should be accurately cut to the frame, a deeper frame or collar should have been used or the frame battened out and it shouldn't have been taped over at the fuse box but locked off. And wires are short. Surely NICEIC should have included this is their report? I personally have a very big issue with gypsum plasterboard being applied to a solid exterior wall as moisture gets trapped behind the gypsum so it's damp between the exterior wall and back of gypsum plasterboard. Damp and a 1in gap between a faceplate and frame is not good news
the person who put the drylining in was the same person as the electrician
