T
the builder is the electrician
corrected that for you .i didn't dot and dab, the electrician/builder did it .
you mean foil plaster board .?lime plaster board to let it breath.
yescorrected that for you .
doesn't he need to qualify to NICEIC standards to be approved ?NICEIC approved is more like it not qualified.
@hoitytoity any chance you could answer my question.My opinion is that the socket box looks fine for a first fix. They’ve even used grommets and earned the backbox. We don’t even know that this could become live as for all we know it could be disconnected at the cu or at another point on the circuit. The gap between the backbox and the plasterboard is a non issue at this stage as there are extension boxes available to bring it out further not that it particularly needs it. As for contacting NICEIC that’s a bit extreme for a first fixed socket. Your concern seems to be about the plasterboard wall getting damp. Have you contacted anybody about that? Even if the backbox was extended it’s not going to stop any dampness so I really don’t get the point of this thread.
Not sure you can get lime plasterboard. Sounds like a big breakdown in communication with the builder/ electrician over the final finish of the wall/rendering.i didn't dot and dab, the electrician did. The walls are solid stone and brick. Yes i agree very poor move for dot and dab
should have been battened and used a lime plaster board to let it breath. Assumed all builders knew that. Damp walls and gap between face plate and frame is not good news.
No.doesn't he need to qualify to NICEIC standards to be approved ?
Even if they think they doNo.
He needs to comply with NICEIC rules to become an Approved Contractor. He doesn't have to be one tho. The NICEIC dont set the 'standards'.
the builder is the electrician. I've said this about 4 times in the thread@hoitytoity any chance you could answer my question.
um no, i have not said the builder was kicked off. I haven't said that once in my threadWalls get dot and dabbed all the time, plasterboard gets cut badly around back boxes all the time... Not a major concern. We get over it.
So the builders been kicked off and your complaining the job isn't finished?! Agree that if that circuit is energised you have some cause for complaint, other than that, stop snagging unfinished work
Who did you say the builder is?the builder is the electrician. I've said this about 4 times in the thread
The problem is not with the electrical instalation. It's with the plaster board.
I think this is an issue with the general building project.
It just so happens the electrician did the plaster board.
This is the problem with being jack of all trades. The spark may be a very competant spark, but not so good plasterboarder.
He's wearing too many hats.
