NICEIC Certification Scheme
Is this work subject to building control?
Why is the wall being boarded over?
What was the brief given to the Builder re materials to be used, is this in the form of a written contract?
Which room is this, if it's a kitchen is the board going to be tiled once plastered?
The problem is not with the electrical instalation. It's with the plaster board.
I think this is an issue with the general building project.
It just so happens the electrician did the plaster board.
This is the problem with being jack of all trades. The spark may be a very competant spark, but not so good plasterboarder.
He's wearing too many hats.
domestic works agreement so builder solution and spec.
Walls get dot and dabbed all the time, plasterboard gets cut badly around back boxes all the time... Not a major concern. We get over it.
So the builders been kicked off and your complaining the job isn't finished?! Agree that if that circuit is energised you have some cause for complaint, other than that, stop snagging unfinished work
it's taped not locked off at fuse box. That's my big issu
