K
Klaudmjj
Thank you for all the replies, I'll definitely wait until I get more experience and knowledge before I use another multi meter at home. Anyways I'm thankful for not getting hurt , definitely learned it the hard way
Hi Klaud, and welcome, the tool kit someone has kindly bought you, is not really designed for Electrical installation work, more for an electronic hobbyist.I want to talk about the context to this first, I'm in my first year at college studying level 2 electrical installation and for Christmas my family got me a toolkit which had some tools , multimeter and a soldering iron. They didn't really know much about things like that and they wanted it to be a surprise so the quality isn't so good, here is the exact tool kit: ZD-961_Tool Kit_Products_Ningbo Zhongdi Industry & Trade Co., Ltd. - http://www.china-zhongdi.com/product/291.html
Okay so I was messing around with the multimeter, turned it to AC voltage, and measured a socket to see if it works. It did, came up with 233v. Then I wanted to measure the amps in the socket, so I changed it to the 10A max , put the test leads inside and theres a big flash , big boom and black around the black test lead and the socket.
I then look at the multimeter, switch it to "20 DC voltage"and it shows a reading although nothing is plugged in , same for "AC volatage" and "Amps" so far the ohms setting is normal.
Now I think what I did wrong, the AMPS had a DC symbol next to and I tried to measure AC or/and the socket is over 10A.
Is there a way to fix my multimeter, or am I better off getting a new one?
Just to be pedantic, if safe isolation is carried out do we need to use insulated tooling?and everything else must be VDE-approved or you are going to zap yourself.
The upmarket ones with a Tee bar ?Just be pedantic - Have you ever tried to tighten the terminal screws on a socket using a watch screwdriver?
Yes, the torque ones.The upmarket ones with a Tee bar ?
Don’t try and start a lengthy debate on New Year’s Eve - sit down and have a Vermouth! Happy New year.Just to be pedantic, if safe isolation is carried out do we need to use insulated tooling?
And if they need to be insulated shouldn't they be to BS EN IEC 60900 rather than an other countries specific VDE?
Good ManI do sometimes work on electronics as a hobby , but thank you for the advice , I'll most likely build my tool kit over time and learn from my mistakes.
I remember load testing a 3 phase generator on a different load bank to one I was used to. It seemed to have dropped 2 phases so I set about fault finding and diagnosed the generator voltage regulator. I quickly changed it and asked a mate to operate the load bank while I watched the generator gauges. Everything was fine and my boss came over for a final check. I started the generator and turned the load bank switches. My mate pointed out I’d only operated 1 phase and you had to do them all independently on this loadbank. Right then he realised that I’d created the fault myself through incorrect use of the loadbank (as did I) as my boss congratulated me for a job well done.Don’t try and start a lengthy debate on New Year’s Eve - sit down and have a Vermouth! Happy New year.
In remembering face palming moments - I remember placing a household thermometer into a pan of boiling water only to find that the water was far hotter than the 37 degree max on the thermometer which exploded over the stove and ceiling. I was just glad it was the Red liquid filling and not the mercury. Anyways I’m still alive but still a bit embarrrassed!
Ok from now on you will only be known, in my household, as Air Commodore Telectrix!my biggest mistake was becoming a spark after turning down the offer of a commission in the RAF, I'd have retired @ 55 with a decent pension.
Mate, I’m 40 and retired from the RAF with a pension, don’t sell yourself short. (*disclaimer* pension is not enough to live on unfortunately)my biggest mistake was becoming a spark after turning down the offer of a commission in the RAF, I'd have retired @ 55 with a decent pension.
