If there is no earth class 2 must be used and preferably have the small white caps over the screws, otherwise to use class 1 you'd be looking at getting an earth into the circuit. Of course making sure it is RCD protected also
house or bungalow?
Approx 15 years ago I had the same problem in a bungalow..
All was ok apart from no RCD and no lighting cpc..
I installed an RCD and a separate 1mm cpc for the lighting circuit..
Yes, the homeowner had blown their budget on fancy light fittings and accessories and didn’t realize they all needed to be earthed..1mm cpc?
The metal back boxes may have nylon type lugs for the front plate screws, if thats the case then they do actually do metal over plates that you mount on the front.... Not the prettiest but if you dont like your white switches and dont want a rewire its an option
Definitely go for an inspection, you will then be given a report with all observations, recommendations, etc
Don't the regs say something about if you have to run a separate earth it had to be 4mm.. or something like that??
4mm if run outside of containment I believe ?
Hi,
I am thinking about getting the property inspected and see what they recommend.
Was that also the case under the old 16th?
The singles that I ran in were insulated and sheathed, as I needed to pick up some live feeds and also at that time it cost less than g/y singles
Not 100% sure about the 16th mate. I'm sure someone will be able to tell us.
Had a feeling it would be, the 16th was very earthy, equipotental/ simultaneous, sinks, windows, radiators - its a lot easier these daysYes 543-01-01 was the same regarding minimum cable sizes in 16th amd 2 : 2004
Well I got around 543-01-01 by using insulated & sheathed singles..
How was the cpc installed?house or bungalow?
I don't, I just rewire.Question people. When you install a 4mm earth, how do you go about connecting it to the light fittings? I thought it would be too big?
Who connects the fittings up?I don't, I just rewire.
Sorry Pete, I wasn't very clear. I mean I don't install a 4mm cpc additional to the existing wiring, I just rewire with new cable incorporating a cpc. The former is an option I wouldn't consider.Who connects the fittings up?
Yes it was definitely a requirement of the 16th Edition.Was that also the case under the old 16th?
The type of cable I’m referring to is brown 1mm singles with integral earth
They were supplementary bonds - not earths.I thought so.. that’ll be why we used to have to put silly 4mm earths between everything in a bathroom
Yes I know but we still used 4mm earth to wire it upThey were supplementary bonds - not earths.
Right I seeSorry Pete, I wasn't very clear. I mean I don't install a 4mm cpc additional to the existing wiring, I just rewire with new cable incorporating a cpc. The former is an option I wouldn't consider.
