Hi,
I have an looking to replace some plastic surface switches and I have noticed that there is no earth wire.
So I don't think I am going to be able to any metal fixings.
What are my options.
  1. Just leave it as it is.
  2. Look to get the circuit re-wired.
Was that also the case under the old 16th?
The singles that I ran in were insulated and sheathed, as I needed to pick up some live feeds and also at that time it cost less than g/y singles
Not 100% sure about the 16th mate. I'm sure someone will be able to tell us.
Had a feeling it would be, the 16th was very earthy, equipotental/ simultaneous, sinks, windows, radiators - its a lot easier these days :)
Well I got around 543-01-01 by using insulated & sheathed singles..
2.5mm is the minimum size if mechanical protection is provided so your 1mm cpc is non compliant even if you do allow the sheath as mechanical protection.
Question people. When you install a 4mm earth, how do you go about connecting it to the light fittings? I thought it would be too big?
No Earth in light circuit
midiman,
Pete999,
