Mine are only 2 ½"...Very true mate. In Yorkshire we had no money so only had 3 inch boards, in Bath with loads of cash 8 inch boards were common...
is that your skirting boards, or yoyr childenMine are only 2 ½"...
What Voltages do you work with in your job 45140Given that the great majority of items requiring to be plugged into a socket are generally used higher up that the floor - computers, radios, TVs, stereo sets, Satellite, electric clock radios, etc. I think it would make more sense to set an "optimum" level for sockets, say 1000mm or thereabouts. Low sockets as someone has already pointed out are difficult for not only the elderly but also anyone with a mobility issue - I for example recently tore all the ligaments in one knee and you would not imagine what an impact that has for reaching down and bending over even now some three months afterwards.
Higher level sockets would also remove the problems with small children poking things in.
Assuming also that the cables are run in the ceiling void there would also financial savings to be gained as well as associated environmental benefits.
Just me or do others agree ?
I recently fitted some sockets in the actual skirting board with the backbox recessed in the wall behind, made good use of the multi tool, feeding cables down behind skirting board to cavity under floor. the skirting was 25cm high, was in a grade 1 listed property. deepest skirting board was just over a foot deep going up stairs and landings, that was on in a old private school building that was being converted to flats.Very true mate. In Yorkshire we had no money so only had 3 inch boards, in Bath with loads of cash 8 inch boards were common...
That’s impressive.Very nice room, that outlet can be relocated with a bit of work. Usually see ones that are a bit too low. Pic is for illustration purposes, not my work.
25kV, 600/400 volt AC, 650-750V DC. Is that relevant ?What Voltages do you work with in your job 45140
No just interested as I was involved in HV work at one time, as an AP HV and AP LV. Thanks. No other reason, didn't mean to be nosy.25kV, 600/400 volt AC, 650-750V DC. Is that relevant ?
If its an old building with a good 1" or more plaster/render then its a simple job using a vibrating multi tool. I Save all my blunt wood blades then use them for cutting out plaster/cement. They do it easy and create very little mess.being able to cut a box in without it looking like a builder/plumber had done it, is an artform on it's own.
I have a 13 year old, he is bigger than me already! I said a few years back "The day you can beat me in an arm wrestle I'll give you £100" he was a skinny little thing at the time so I thought it will be a while before I have to shell out some cash. Hmmm... we had an arm wrestle on Friday and it took all my strength to beat him. Obviously I pretended it was easyfitting sockets @ 450mm is a good idea. light switches @ 1200mm is bad as children can reach them. then again, children pre-teens should be kept in a cage. once 13, then sheds are useful.
Hi Pete, No worries, nothing secret about it, just wondered. I think HV work is easier to be honest !No just interested as I was involved in HV work at one time, as an AP HV and AP LV. Thanks. No other reason, didn't mean to be nosy.
Not much room for making mistakes though, one hit from 11KV and your done for.Hi Pete, No worries, nothing secret about it, just wondered. I think HV work is easier to be honest !
I hear that Screwfix are doing some good deals on skirting-board ladders at the moment.I recently fitted some sockets in the actual skirting board with the backbox recessed in the wall behind, made good use of the multi tool, feeding cables down behind skirting board to cavity under floor. the skirting was 25cm high, was in a grade 1 listed property. deepest skirting board was just over a foot deep going up stairs and landings, that was on in a old private school building that was being converted to flats.
