Just renovated my house and put the sockets where I wanted. Biggest problem was getting them level with each other when first fixing the back boxes into bare sand stone.
Given that the great majority of items requiring to be plugged into a socket are generally used higher up that the floor - computers, radios, TVs, stereo sets, Satellite, electric clock radios, etc. I think it would make more sense to set an "optimum" level for sockets, say 1000mm or thereabouts. Low sockets as someone has already pointed out are difficult for not only the elderly but also anyone with a mobility issue - I for example recently tore all the ligaments in one knee and you would not imagine what an impact that has for reaching down and bending over even now some three months afterwards.
Higher level sockets would also remove the problems with small children poking things in.
Assuming also that the cables are run in the ceiling void there would also financial savings to be gained as well as associated environmental benefits.
Just me or do others agree ?
What Voltages do you work with in your job 45140
Very true mate. In Yorkshire we had no money so only had 3 inch boards, in Bath with loads of cash 8 inch boards were common...
I recently fitted some sockets in the actual skirting board with the backbox recessed in the wall behind, made good use of the multi tool, feeding cables down behind skirting board to cavity under floor. the skirting was 25cm high, was in a grade 1 listed property. deepest skirting board was just over a foot deep going up stairs and landings, that was on in a old private school building that was being converted to flats.
25kV, 600/400 volt AC, 650-750V DC. Is that relevant ?
No just interested as I was involved in HV work at one time, as an AP HV and AP LV. Thanks. No other reason, didn't mean to be nosy.
being able to cut a box in without it looking like a builder/plumber had done it, is an artform on it's own.
If its an old building with a good 1" or more plaster/render then its a simple job using a vibrating multi tool. I Save all my blunt wood blades then use them for cutting out plaster/cement. They do it easy and create very little mess.
fitting sockets @ 450mm is a good idea. light switches @ 1200mm is bad as children can reach them. then again, children pre-teens should be kept in a cage. once 13, then sheds are useful.
I have a 13 year old, he is bigger than me already! I said a few years back "The day you can beat me in an arm wrestle I'll give you £100" he was a skinny little thing at the time so I thought it will be a while before I have to shell out some cash. Hmmm... we had an arm wrestle on Friday and it took all my strength to beat him. Obviously I pretended it was easy :tongueout:, kids seem to be so big these days!
Hi Pete, No worries, nothing secret about it, just wondered. I think HV work is easier to be honest !
Not much room for making mistakes though, one hit from 11KV and your done for.
I hear that Screwfix are doing some good deals on skirting-board ladders at the moment. :cool:
