Is that 2.8 Meg?was still live, about 2.8M above the ground in a publicly accessible place.
Is that 2.8 Meg?![]()
I was thinking it was probably very damp.Presumably as the earthed metal disappears the insulation readings to earth go up!
No, but I recall the jokes around the time, no picture it's probably the picture valve. Later used for transistorised tv's, also. I repair most things these days.With a name like picturevalve, I bet you're an ex TV repairer.
No the earth cable you see has been used as the neutral link from main switch with black tape . Take a closer look at the bus bar
A join in the bus bar at the first MCB?No the earth cable you see has been used as the neutral link from main switch with black tape . Take a closer look at the bus bar
No Look at how the bus bar connects to the main switch a bit of 4mm cable !!!!!!!!!!No cover over the bar and it looks a little long?
I thought we were looking for something strange. Busbar with no cover is hardly a rare occurrence.
Almost correct The bus bar is connected to the main switch by some 4mm cableA join in the bus bar at the first MCB?
Be nice if you could see that from the pictue without mega zoom.No Look at how the bus bar connects to the main switch a bit of 4mm cable !!!!!!!!!!
[automerge]1569591174[/automerge]
here a close up for you .the clues where there,Be nice if you could see that from the pictue without mega zoom.
