richy3333
Mentor
Supporter
Can anyone tell me what the fittings are for this. I assume Some sort of proprietary Lewden lighting system? Its a mini chandelier and a cover slides on to this. Spade connectors do not fit the lugs. A customer has asked me to wire it up for them (they had it removed from another house and dont know how it was fitted).
Come in 2 parts , the base that you wire up and screwed to the ceiling and the bit with pins and the hock you attach to the base.
Used for heavy chandeliers so the cleaner could take down to clean the crystal
@Dustydazzler I have the base and fancy light part. So is there something I can access in the base to wire into? (I only saw it briefly).
Thanks for the help
Thanks for the help
See link in DT1991 post above , if you have both parts then it will become very clear how to use it...
Another similar link
richy3333
Mentor
Supporter
Far North Scotland
Lewden chandelier
Lighting Forum
richy3333,
Marcus Vaughan,
