L
Let me think
Hi folks,
Friend is currently renovating his house, including a loft conversion. He had originally hoped to go with Grade F1 (tamper proof batteries) radio interlinked alarms. However architect has stipulated all alarms must be Grade D (mains powered with battery back-up), but can be still be radio interlinked.
All walls and celling's are up, plastered and painted. So looking to minimise damage where possible when installing.
It's going to be pain to run a separate circuit from CU for alarms and to have them hardwired interlinked, but if needs to be done that way then so be it. Same would also apply if running separate mains alarm feed cable connecting into lighting circuit MCB at CU.
So was wondering what your views would be on doing the following (not ideal in my mind, but a possible workaround).
Look forward to your input.
- Downstairs alarms mains feed of downstairs lighting circuit (can 'easily' access - minimal damage).
- Upstairs alarms mains feed of upstairs lighting circuit (can 'easily' access - minimal damage).
- All alarms radio interlinked (could hardwire interlink downstairs, hardwire interlink upstairs with radio interlink between upstairs and downstairs).
