Let me show you my first soldering.
This is my first attempt:
This is my second attempt:
Please, be gentle. :)
Also, it sometimes makes things easier if you add a bit of fresh solder after you have removed as much as you can of the old stuff. Don't try to suck up too much in one go with the desolder pump, then you won't keep blocking it.
I plan to buy temperature controlled soldering iron in future, but for now I don't need it, current one is sufficient, it does ok job.
I will buy desoldering wick to see if it's better for smaller joints, I just couldn't desolder them with pump.
Solder wick is very useful. Beginners can sometimes pull PCs tracks off though so be careful.
[automerge]1593359129[/automerge]
Should have said PCBs but too late to edit it.
How to solder to my standards. Another example: 6mm² tap into an unbroken run of 16mm².
The strands of the main run are parted, 3 to one side and 4 to the other, and the tap cable passed through the gap. The gap is then closed up with pliers and the strands wrapped around the main cable, again split into 3 & 4. The wraps are tightened with pliers and soldered. For this demo I have set the tap cable at right-angles for clarity; it can just as easily be soldered in a Y-position.
In this case I used a stick of tinman's solder (40/60) and a touch of Fluxite. My choice of iron here was the trusty 240W Henley; it's a good allrounder and when working on the bench its weight is not much of a hindrance. OTOH the heavy tip stores a lot of heat and can raise a large job to working temperature very quickly, so anything that is too large for this tends to be blowlamp or pot territory.
After soldering, the work was cleaned of flux and residues with a rag and thinners, then the tap cable dressed into the Y position to enable the adhesive-lined heatshrink to be fitted. Note that with just ordinary heatshrink, it is not possible to make the joint watertight, as there will be a void between the two parallel cables. Either a Y-boot or some additional hot-melt is needed to seal it fully. Finally a cable tie holds the tap cable to the run to avoid stretching the heat-shrink while handling.
I'll write about desoldering from a PCB next time.
I have bought solder wick and I managed to desolder LED diode I previously couldn't with sucker (in red circle).
I have tried to desolder mouse buttons (in green circles) with wick but it just didn't absorb solder. Solder just didn't want to melt, I then added some solder on all joints and then I used pump and I managed to remove solder but I still can't remove buttons, there are some small fragments of solder holding component legs.
I solder two wires onto LED diode to practice, I hope I did it right. I first tinned wires and then I just put soldering iron on diode's legs and joined wires. Is that process ok?
I tested connection, LED diode lights up! Yeah!?
This is often needed, I do it all the time.
Maybe not enough heat, but this is another common problem. Try moving the component slightly as the residual solder cools, so that it makes a weak bond. Sometimes it helps to push the component lead one way or another with the iron, to stop it pressing against one side of the plated-through hole to which it will tend to bond again even with very little solder. If there's just 0.1mm clearance, the solder bond will be much weaker. It's always a compromise between damaging the PCB with too much heat while removing the solder, and damaging it by pulling the tracks and vias off because too much solder is left behind.
Yes, for connections that can be completed quickly. Tinning is really to prepare the surface, ready for fresh solder to be applied to make the joint, and with that fresh solder comes fresh flux. Always tin both parts if possible. In this kind of situation where you are just lap-jointing two wires, you can usually leave enough solder on the wires that no more needs to be added (and therefore do the work with two hands instead of three. But for this to work properly, the flux still needs to be active, not burnt or oxidised, when the parts are brought together and the solder re-flowed. If you can tin the parts in under one second each, the flux should still be OK, otherwise you will want to add a touch more solder or flux to re-flow. Half a second to tin and one second to re-flow is about the maximum.
I am not sure if my soldering iron has enough heat, since this is my first ever, but I couldn't melt solder of components.
I am not sure if my 30 watts iron really gives 30 watts of power, it's a cheap iron from local DIY store, its Womax LP-30.
When I do tinning, tin melts right away.
The iron probably has enough power for the PCB work you are doing, but I would try a bigger tip for the bigger joints. A bigger tip transfers more heat to the joint.
If you have a reel of old style 60:40 tin-lead solder then it melts at a lower temperature than the lead-free used on most electronics these days. That might be a reason.
Yes, I have 60/40 1mm tin.
What temperature or soldering iron power is needed for lead-free solder?
[automerge]1593504645[/automerge]
Unfortunately, tip is not replaceable.
Just the tip. I would try taking the existing one out (when it's cooled down obviously!) and measure the diameter and length of it.
buy a 100 watt weller gun. does most work but on smaller joints you need to be careful of overheating. i used one on TV repairs in the 70's and 80's. did everything i wanted.
I missed out the step ,crafting hole/gap in straight through cable.
(and damaged conductors attempting to form wanted shape -when cold)
(Also ignore peculiar colour choices -and no sleeving)
--Would this joint ever crystalize grey in time ?--
Point of photo --
practice run - "Have a good laugh"
- heat build-up damaging insulation
- solder wicked along making it hard to shape
( Suspect soldering iron was inadequate - Finished
it off with ....
(More mechanical insulation damage )
Point of photo --
it off with ....
Looks like Alien 3.
Point of photo --
it off with ....
bloody hell. that looks like a plumber's disaster.
Point of photo --
it off with ....
Can I give you my neighbour phone number? He has some problems with wires installations in home.
Yes, it will transfer more of the heat to the joint due to the larger contact area. Admittedly it will still struggle with the bigger things on that PCB.
The problem (as mentioned in My first soldering! - https://www.electriciansforums.net/threads/my-first-soldering.186729/post-1639486) is I guess lead-free joints that my soldering iron is not capable to melt due to low heating temperature. I have used sides of tip for larger contact area on joint but no success. Only thing that worked was adding 60/40 solder on joint and then melt it and removed with pump.
How can you tell is solder lead free or not ?
Visually solder joints on PCB look a bit darker, but maybe it's because of time pass.
I remember melting solder in a candle aged 10 or so.
( I got my father to solder wires to pcbs )
.. Solid wire wrap wire being a pain for losing it's insultion springs to mind .. But shame of end result prevents any memeory !
I bought 60W soldering iron, and now I can easily desolder components from PCB, which I couldn't with 30W iron due to lead-free joints.
I must say that 60W is a bit stronger/hotter then I would like to, I think 50W would be perfect for all. I just need to work a bit faster with 60W.
Buying a soldering station as suggested at the beginning of this thread, you can adjust the temperature to that required for the task, it's a false economy to keep buying soldering irons at different wattage's to get over the problems encountered.
I didn't bought station because I still don't need it, and it's a bit expensive compared to my needs. I could've buy cheaper ZD-99 station for 20 euros, but if I buy station I will buy really quality station, but that's in the future, just not now.
For desoldering on PCBs applying some flux from a flux pen to the joints before desoldering will often help a lot. I've been using temperature controlled soldering stations for the last 17 or so years and wouldn't be without now. I do use a standard 80W iron for soldering larger wires such as shown in Luciens example above as they can dump a lot of heat into the joint so it can be soldered fast before all the insulation starts melting. A higher wattage iron is needed for most modern pcbs that have more than one track layer, some multilayer boards can have substantial amounts of copper in the inner layers for power rails that can sink the heat away. If the joint isn't heated up enough the plated through holes can be damaged when the component lead is pulled out.
My current iron for PCB work is a 130W JBC, a fantastic tool, bit rather expensive...
Europe
All Other Countries (This Is English Speaking Website Only - WE don't mind Google Translate Users :)
My first soldering!
Elecmox,
Elecmox,
