Discuss Advice on testing RBOS in prison in the UK Electrical Forum area at ElectriciansForums.net
Do they trip on the self-test button?
[automerge]1593899196[/automerge]
I seem to recall someone pointing out that in some types of RCD device the current sense transformer is not always fully before the terminals so testing at the screws might not match the out-going wires.
Of course I might be havering!
Yes Memshield 2 which is why I asked in #2.
I have C/U with memshiled MCBs in. I have converted some to RCBO via the MEM pod which clips to the top of the MCB. I guess this is how most of the memshiled RCBOs are done. the pod has a flying N lead and N terminal but the Line conductor is fed though a hole in the pod (though RCD coil) and it is terminated in the screw terminal on the top of the MCB. So as said above testing on the screws will mean you are connecting Line before the RCD coil
I had a pod that was broken and was spare so had a look inside, here it is incase interested
Reply to Advice on testing RBOS in prison in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
Hello fellow sparks, I’m looking to do my testing and inspection course which starts on the 30th of April, but I have not got much testing...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
I sorted the fault fairly quickly as it happens but only because I'd come across it once before and at the time a few people said it couldn't...
Hi I am asking for help as a novice and 1st time user of this forum. Recently started to experience tripping of MCB & sometimes with the RCD at...
