inside a 22kw motor on a machine that i was fault finding today.
strange, at panel end, all motor cables had good continuity to earth. (expected to find a well burnt out motor)
went to motor to check out there and all was fine.
opening cover had removed the short to earth.
got to love the old wire nuts!!!
I don’t know wether to be proud or disappointed with myself that I’ve never looked a plug and even considered that as an option.....@littlespark nails it....that is special!!
It works great for adaptors fitted with the little round euro plug pins, or so I would imagine anyway...
Need to admit something.
when visiting New Zealand a few years ago I bought hair clippers as I needed a trim.
Of course, when I brought them home, they were useless without an adaptor.
lockdown hits, and I needed a haircut.
So plugtop, a length of flex and some insulating tape.... “safely” enclosed in my garage. Charged up the clippers no problem until I got a proper adaptor
Called in to sort a not working light. DIY light replacement on 2 way switching, neutral lost but dodgy as hell.
that is pure sh one t workmanship
I was thinking the same - full marks for improvisation. And TBH, not really that much wrong with it is there ? I think the most dodgy part will be how to get little wires to fit properly in a connector block that fits a 13A plug pin.
Need to admit something. ...
Well ... remember when those 2.5A cloverleaf connectors first started appearing - especially on computer stuff ? Well of course, the first time you come across one, you don't have a spare cable, and so it was that one day someone came to me with "I've forgotten the cable for my laptop and the battery is nearly flat ?" Of course, I had a reputation to keep up as "the guy that can do anything if you ask nicely" so I had a little think. So out of sight, two bare ends, some insulation from cores about the right size to fit on the pins to hold the wires in place, charged the laptop up for the nice lady. Naturally there was no way I was letting that improvisation anywhere someone unskilled could get near it.
Yuck.
A while ago I got asked if I'd help no 1 daughter's friend with a couple of lights he'd bought. That was a "WTF were they thinking" moment when I had a look at it. One of those central ceiling plates, with 5 (yes, FIVE) arms sticking out with SES lampholders on the end for candle bulbs. Simple enough according to the destructions - all you have to do is put the five pairs of wires into chock blocks and connect them to the ceiling wiring. Yeah right, even with the 5 pairs all shortened it was "a bit if a faff" to get the fitting in place o_O What fun, trying to herd all the wires into place, sufficiently neatly that the fitting would go on it's bracket, then hold it there while getting a screw with one hand, a screwdriver with the third hand, and while holding on to the ladder with the fourth hand - or that's what it felt like.
Every now and then I remember that I've not been back and done the other one :rolleyes: If I do remember to it, I'll neatly dress the pairs, and crimp things together so there's just one pair of wires to connect up.
Reactions: pc1966 and DPG
I find those type of push fit connectors can be very tricky with flex, takes the knack to get them to grip properly and easy to get it wrong. No excuse for the mess they made of it overall though!
[automerge]1599783177[/automerge]
Was it poor connection inside the wire nut that had caused the melt? or overload?
I still have a few from when Ideal tried to bring them back over here maybe 10 years ago? Never tempted to use them, though I have a couple of the waterproof gel filled ones in my bag for outdoor bodgery...
As far as I can tell, it was not an overload, it is inverter controlled and the current limits set correctly.
Working on the assumption that it was a poor connection as the others were ok and it is an equal load on all of them
Reactions: Dartlec
Doing a job at a property today and been warned this might be next - not sure I want to do a good job and encourage them!
2020-09-14 14.55.42.jpg and just above it: 2020-09-14 14.55.48.jpg
don't tell me, replace cooker isolation switch.
cant damage tiles or cupboard because they have just been installed?!!!
Reactions: nicebutdim
Good grief you would have to be either very lazy or very stupid to install the kitchen unit over the switch like that. Not to mention it looks awful.
Reactions: nicebutdim and DPG
Nothing wrong with a good steak pie made with good ingredients pirate, balanced diet is the answer....so I balance pies with some veg and Guinness ?
[automerge]1599760638[/automerge]
C’mon that is creative engineering there! ?
veg. my arse. a balanced diet is a pie in each hand with beer close by.
Previous owner DIY'd it apparently, so hopefully they are planning to retile. All a bit odd - all RCD sockets in the kitchen, though a dual RCD CU was installed in 2015.
Oven that's blocking that switch doesn't seem to be run from it (might be from a socket outlet if that switch has one behind the cupboard - in which case a 4.1kW oven is running off a 13A plug)
And an Elecsa EIC for the new board that claims the 6mm Cooker circuit has ring continuity while the 2.5mm "Ring Circuit" doesn't :rolleyes:
Not to mention that it claims 10mm main earth when the feed is 16mm T&E, and the 2 10mm g/y cables leaving the CU don't go back to the MET.
Going to be a fun can of worms to open.
Still, on the plus side I installed a new Fusebox CU at the source today (adding a couple of circuits in a porch) so they have SPD for the installation and proper bonding at least.
Reactions: freddo
Classic case of "job and finish" fitting a cupboard like that. No concern for the future use, no pride in workmanship, just shove it in and take the money. Makes me very angry...and seen far too often. Bet the fitter said proudly to the homeowner "Look, there you go, I've cut that just perfect so you can still use the switch".
However, it could be fun if you were ever called to rewire Kev's house...T&E clipped direct to the tiling in the kitchen, use up all your round edged socket plates on his square edged back boxes, and of course use plasterboard screws for everything, and no wall-plugs...
Except, Electricians have standards to adhere to...
Landlords mains board installed in 2018.
Column light which had been replaced a month ago and was flickering.
8K
Darkwood,
mainline,
