Darkwood
Can’t get my handle on the fault
Many years ago when we first moved to Scotland, we decided to add concealed bolts to the double doors into the garden (this sort of thing https://www.screwfix.com/p/era-brass-concealed-door-security-bolts-60mm-2-pack/5748G)
So he carefully marked the holes, removed the doors so he could drill for the bolt from below and above as they couldn't be done in situ.
He made a really good job tbh.
But when he put the doors back on, it turned out he had drilled and fitted the escutcheons for the star key on the OUTSIDE!!!
He wasn't a happy bunny, threw a nice 5 year old style tantrum!
i Used to always panic drilling blind through walls even after measuring to predict where the drill would poke out...
there are quite a few houses where I live plumbed using micro bore copper pipe buried in the plaster , it goes any where and everywhere with no thought or zoning
Friend sent me this from a boating forum
Looks good to me!
That’s a fire waiting to happen, those fuel cans are sh1te and leak out the vented caps when bouncing around. Whoever thought to store them alongside the batteries with that abomination of wiring is a total genius.
I’m going have to share this photo with a few of my marine engineering mates.
I’ll report back their thoughts. ?
Looks like a good idea to me. I'm in the middle of doing some decorating and I'm planning on putting a new socket in. If I just chisel out enough to glue the socket in then all I need to do is run a 45 deg channel to the new socket. The current one is already a spur so I'll just use 1mm cable (got a reel of black in the van) so that I don't overload it and job done. Saves on the cost of a back box and less work.
you could be on to something ...
8K
Darkwood,
mainline,
