Discuss Help regarding 2365/5357 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
you need to show on drawing for question C , switched socket outlets for a kettle, TV phone charger / laptop in each room (use OSG to put minimum number of socket outlets per room depending on size, you also need to show FCU for 700W heating/cooling and FCU for bathroom towell rail.
For question D show position of DB in each room and each of the above circuits coming from this db
label each circuit (for question e) i.e R1R for room 1 ring R1H for room 1 heating R1 TR for room 1 towel rail, the R2R for roomn2 and so on.
include a legend showing symbols used
Why 8 CUs?
It states it
Cheers mate , appreciated.
Why 8 CUs?
D Show, on either electronic or hard copies of the drawing, how each circuit in the new hotel
extension is to be arranged. The arrangement must take into account that a fault in any one
room must not effect another room.
becouse it is one way of achieving the question. There are other ways of achieving this.
the assignme
What do you mean? where does it state that each room should have its own CU?
the assignment spec says "
"d) Show, on either electronic or hard copies of the drawing, how each circuit in the new hotel
room must not effect another room." ONE way to achieve this is to have a seperate DB in each room. but it could also be achieved in other ways.
The spec also states
c) Show, on either electronic or hard copies of the drawing, positions of socket‐outlets and
fused connection units for the new hotel block giving consideration to the following items of
equipment in each room
 kettle
 TV
 provision for phone charging and/or laptop use
 supply to a 700 W air handling unit for heating/cooling (installed by specialist)
 electric towel rail.
NO NEED TO SHOW LIGHTING IN HOTEL EXTENSION
the assignme
 kettle
 TV
Oh right thanks
Please find attached the pdfs for the project. You can either print them at your leisure, throw into mspaint/visio/cad and mark electronically.
  • 2365_and_5357_l3_assignment_drawings_v1-0-pdf.ashx.pdf
Reply to Help regarding 2365/5357 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Electrical Courses
